EXAIR offers high-capacity quality HEPA vacuum
By Lisa Eitel | May 22, 2019
EXAIR’s compressed air operated Heavy Duty HEPA vac attaches to an ordinary 30, 55, or 110 gallon open top drum to turn it into a powerful, HEPA (High Efficiency Particulate Air) quality, industrial vacuum cleaner. Like the Heavy Duty Dry Vac, it’s powerfully designed to move more material with less wear.
Engineered for dusty environments that require regular cleaning, the HEPA filter is designed with high capacity in mind. Ordinary vacuums can clog up quickly in environments with an abundance of dust or particulates. An economical, easily maintained pre-filter stops larger particles of debris while the HEPA filter handles smaller matter. The Heavy Duty HEPA Vac does not use electricity and has no moving parts, assuring maintenance free operation.
The Heavy Duty HEPA Vac’s lever lock drum lid fits any open top 30, 55 or 110 gallon drum. Moving it from one drum to another can be done quickly, making it easy to keep different materials separate for recycling. For more information, visit www.exair.com/58/hepa.dirpr.htm.
In addition, EXAIR is offering a special right now on all of their Industrial Vacuums. Learn more at www.exair.com/58/vacpromopr.htm.
Filed Under: Filters (mechanical) for air + fans, FLUID POWER, MECHANICAL POWER TRANSMISSION, MOTION CONTROL
Lisa Eitel
