EXAIR’s new 30 Gallon Heavy Duty HEPA Vac is a powerful, HEPA quality, industrial vacuum cleaner. This smaller volume drum means that it will fit in tighter spaces and is suited well for less frequent or lower volume applications. The Heavy Duty HEPA Vac is designed to move more material with less wear. It has been engineered to filter contaminants to HEPA requirements in dusty environments needing frequent cleaning.
It is extremely quiet at 82 dBA (half the noise of electric vacs) making it suitable for a wide variety of environments. An economical, easily maintained pre-filter stops larger particles, while the HEPA filter handles the smaller matter. All filters are tested for minimum 99.97% filtration at the 0.3 µm level to meet HEPA standards in strict accordance to IEST-RP-CC-007.
EXAIR’s Industrial Housekeeping product line offers wet or dry vacuums from 5 gallons up to 110 gallons of capacity. They are available to outfit existing drum or can be purchased with the complete drum assembly. Plastic or heavy-duty aluminum vacuum tools are available. All EXAIR vacuums are CE compliant and carry a 5 year “Built to Last” warranty. Heavy Duty HEPA vacuum prices start at $1,570. For more information, visit www.exair.com/58/hepa30.htm.
