Easy Integration of Stäubli Robots with uniVAL Drives on POWERLINK Networks
By Design World Staff | April 25, 2011
Robots from Stäubli can now be directly operated with B&R controllers. This is possible thanks to a POWERLINK interface on Stäubli’s uniVAL drives that allows Generic Motion Control programs from B&R controllers to be transferred to the robots. In this way, robotics engineers can use the uniform programming and operating environment provided by B&R controllers.
Robot from Stäubli
Robots are connected to the network using POWERLINK, the real-time Ethernet standard. When using a higher-level controller, the controllers for the Stäubli robots are switched into passive mode, which still allows them to check whether incoming control commands are valid with regard to kinematics and safety.
The uniform operating interface means that system operators can save time, money and work during commissioning and servicing. For machine manufacturers, the reduction in interfaces doesn’t just mean a lower selling price, but also shorter cycle times in production, cutting costs there as well.
In addition, the shared POWERLINK network also offers fully uniform diagnostic support as well as the ability to implement comprehensive solutions – from the visualization application and motion/robot control all the way to integrated quality control via image processing in a true real-time network.
B&R Industrial Automation Corp.
www.br-automation.com
Filed Under: Factory automation, Automation components, Motion control • motor controls, Mechatronics, Networks • connectivity • fieldbuses
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
