    • Subscribe!
EXAIR’s High Lift Drum Vac uses compressed air to move thick liquids
By Kelsey Zebrowski | April 20, 2020
EXAIR’s compressed air operated High Lift Reversible Drum Vac System provides maximum lift of up to 15 feet. This two-way can move thick liquids up to 1400 cP through 20 feet of hose and attaches quickly to any closed head 30, 55 or 110 gallon drum.
The High Lift Reversible Drum Vac is able to fill a 55 gallon drum in less than 85 seconds. With the simple turn of a knob, the same stainless steel pump quickly empties the drum. The High Lift Reversible Drum Vac has the extra power you need to move liquids from below grade work areas, sumps or tanks up to 15 feet deep.
Like all of EXAIR’s industrial vacuums, the High Lift Reversible Drum Vac uses no electricity and has no moving parts which assures maintenance free operation. It is designed for continuous and heavy-duty applications where electric vacuums fail due to motor wear or clogged impellers. This vacuum efficiently and safely uses the compressed air in your facility. An automatic safety shutoff valve prevents overfilling.
EXAIR is offering a special right now on all Industrial Vacuums. For more information, visit exair.com.
You may also like:
  • Dual 316SS Cabinet Coolers with digital control resist heat and…
  • Filter out chips with EXAIR’s Chip Trapper
  • Exair no drop atomizing nozzles
    No-drip air atomizing nozzles conserve precious liquids
  • EXAIR’s single point ionizer for spot neutralization
  • EXAIR 303SS air conveyor converts standard pipe to convey in…
Filed Under: Pumps
Tagged With: exair
ironhorse-AD-jet-pump-image
IronHorse jet pump and stainless steel motors from AutomationDirect
KNF’s Diaphragm Liquid Pump FP 70 provides a smooth flow and high efficiency solution
KNF’s new smooth flow, high efficiency diaphragm liquid pump FP 70
spartan scientific high-pressure solenoid pump
High-pressure solenoid pump offers fluid control for rigorous needs
    • Subscribe!
