Fabco-Air – Pneumatic slide tables on rail bearing system
By Editor | September 12, 2012
Series FGXS is a twin bore, precision table slide, which uses a rail bearing system for smooth operation. Dowel holes and slots on the table surface enable accurate, repeatable work piece mounting. Magnetic pistons and sensor mounting slots are standard. Optional sensors feature surge protection, polarity protection, LED indicator, and fast switching speeds. Slide units may be mounted through side-tapped or end-tapped holes, or with side body through holes. Options include adjustable stroke and shock absorbers. Bores are 6 mm to 25 mm and strokes up to 150 mm.
Fabco-Air, Inc.
www.fabco-air.com
Filed Under: Pneumatic equipment + components, Surge protection
Tagged With: fabcoair
5 ways to improve packaging machinery with smart pneumatics
Clippard-Cordis-CFC-electronic-Flow-Controller
Cordis flow controller offers high resolution and repeatability in a closed-loop system
Upgrading equipment with solenoids
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
