Festo has developed the VTUG multipin pneumatic valve terminal — an universal valve apparatus with several electrical connection options, providing machine manufacturers and end users greater versatility for easy installation and control.
The VTUG multipin pneumatic valve terminal is designed for various industries such as light assembly, semiconductor, electronics, packing, food and beverage. Aside from that, this device delivers optimal performance, with high pressure and a high flow rate despite its small size.
In addition, the VTUG is controlled and connected via ribbon cable connectors or a D sub for easy connectivity and simple system integration. These connectors can be swapped for an iport connector, enabling linkage to industrial Ethernet protocols, various fieldbus and the industry standard IO-Link network.
The VTUG multipin pneumatic valve terminal is also offered with different pneumatic working port connection options, such as semi-inline options, sub-base options, as well as a sub-base solution with working ports beneath. This makes the device an excellent choice for control cabinet installation, since the manifold itself is part of the cabinet.
Festo
www.festo.com
Filed Under: Pneumatic Tips
