In the last two decades, humanity has discovered thousands of extrasolar planetary systems. Recent studies of star- and planet-formation have shown that chemistry plays a pivotal role in both shaping these systems and delivering water and organic species to the surfaces of nascent terrestrial planets. Professor Geoffrey A. Blake in Chemical Engineering at the California Institute of Technology talked to Duke faculty and students over late-afternoon pizza in the Physics building on the role of chemistry in star and planet formation and finding other Earth-like planets.
In the late 18th century, French scholar Pierre-Simon Laplace analyzed what our solar system could tell us about the formation & evolution of planetary systems. Since then, scientists have used the combination our knowledge for small bodies – asteroids – and large bodies – planets – to figure out how solar systems and planets are formed.
In 2015, Professor Blake and other researchers investigated more into ingredients in planets necessary for the development of life. Using the Earth and our solar system as the basis for their data, they explored the relative disposition of carbon and nitrogen in each stage of star and planet formation to learn more about core formation and atmospheric escape. Analyzing the carbon-silicon atomic ratio in planets and comets, Professor Blake discovered that rocky bodies in the solar system are generally carbon-poor. Since carbon is essential for our survival, however, Blake needed to determine the range of carbon content that terrestrial planets can have and still have active biosystem.
With the Kepler mission, scientists have detected a variety of planetary objects in the universe. How many of these star-planet systems – based on measured distributions – have ‘solar system’ like outcomes? A “solar system” like planetary system has at least one Earth-like planet at approximately 1 astronomical unit (AU) from the star – where more ideal conditions for life can develop – and at least one ice giant like Jupiter at 3-5 AU in order to keep away comets from the Earth-like planet. In our galaxy alone, there are around 10 billion stars and at least 10 million planets. For those stars similar to our sun, there exist over 4 million planetary systems similar to our solar system, with the closest Earth-like planet at 20 light years away. With the rapid improvement of scientific knowledge and technology, Professor Blake estimates that we would be able to collect evidence within next 5-6 years of planets within 40-50 light years to determine if they have a habitable atmosphere.
How does an Earth and a Jupiter form at their ideal distances from a star? Let’s take a closer look at how stars and planets are created – via the astrochemical cycle. Essentially, dense clouds of gas and dust become so opaque and cold that they collapse into a disk. The disk, rotating around a to-be star, begins to transport mass in toward the center and angular momentum outward. Then, approximately 1% of the star mass is left over from the process, which is enough to form planets. This is also why planets around stars are ubiquitous.
How are the planets formed? The dust grains unused by the star collide and grow, forming larger particles at specific distances from the star – called snowlines – where water vapor turns into ice and solidifies. These “dust bunnies” grow into planetesimals (~10-50 km diameter), such as asteroids and comets. If the force of gravity is large enough, the planetesimals increase further in size to form oligarchs (~0.1-10 times the mass of the Earth), that then become the large planets of the solar system.
In our solar system, a process called dynamic reorganization occurred that restructured the order of our planets, putting Uranus before Neptune. This means that if other solar systems did not undergo such dynamic reorganization at an early point in formation of solar system, then other Earths may have lower organic and water content than our Earth. In that case, what constraints do we need to apply to determine if a water/organic delivery mechanism exists for exo-Earths? Although we do not currently have the scientific knowledge to answer this, with ALMA and the next generation of optical/IR telescopes, we will be able image the birth of solar systems directly and better understand how our universe came to be.
To the chemistry students at Duke, Professor Blake relayed an important message: learn chemistry fundamentals very carefully while in college. Over the next 40-50 years, your interests will change gears many times. Strong fundamentals, however, will serve you well, since you are now equipped to learn in many different areas and careers.
