Flexible Cable Assemblies Offer Low VSWR through 18 GHz
By atesmeh | January 13, 2010
Electronic Assembly Manufacturing announced the release of low VSWR flexible cable assemblies featuring Times Microwave Systems T-Flex cable. Three-foot long, 0.141” diameter assemblies, terminated with SMA male connectors, exhibit VSWR characteristics of 1.35:1 from 45 MHz to 18 GHz. Suitable for applications through 20 GHz, these 50-ohm flexible cable assemblies meet all MIL-C-17 requirements. EAM’s flexible cable assemblies feature desirable corrosion resistance with stable attenuation and phase characteristics over time. Shielding effectiveness is comparable to standard semi-rigid cables. Available in standard and custom lengths, these flexible cable assemblies feature PTFE (Teflon) dielectric with silver plated copper tape and braid shield and fluorinated ethylene propylene (FEP) jacket.
978-374-6840, www.eamcableassemblies.com
