GAM with Jakob Antriebstechnik and GF Machining Solutions will be Speaking at IMTS
By Marisa Martin | August 11, 2016
A short description:
Different causes lead to unforeseen contact situations between moving components in the working space of machine tools. These collisions can result in damage of the machine components. High cost and machine downtime are the consequences. This article presents a solution for the reduction of contact forces in case of collision. The damages of the machine structure and the main components like the motor spindle can be successfully avoided. Further a modified mechanism with higher stiffness and better process properties of the protection system will be described and compared to the current status.Screen Shot 2016-08-11 at 12.18.39 PM
This technology will be shown at IMTS 2016 and installed on GF Machining Solutions high performance milling centers model Mikron HPM 800 U ST with crash demonstrations several times per day. GF Machining Solutions is located at S-8754. In addition, FFG MAG will have the spindle protection system displayed at IMTS in their booth S-8129. This unit has been successfully tested in their Specht HMC 600.
IMTS
www.imts.com
Filed Under: 3D printing • additive manufacturing • stereolithography
Tagged With: imts
PCB mills
September 2020 Special Edition: 2020 Additive Manufacturing Handbook
The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
Top 3 reasons why you should consider additive manufacturing today for production parts
