    • Subscribe!
GE Fanuc Introduces Scalable High Availability Solution for PACSystems® RX3i Controller
By Design World Staff | June 4, 2009
Charlottesville, VA – GE Fanuc Intelligent Platforms, a unit of GE Enterprise Solutions, announces the introduction of its scalable high availability solution for the company‚’s industry-leading PACSystems‚® RX3i controller. By combining essential processes and capabilities onto one platform, the PACSystems RX3i controller is one of the most powerful, scalable, flexible, and efficient means to increasing productivity. It now adds high availability to its multi-domain functionality along with logic, motion, HMI, and process control.
Built on a synchronized hot-standby redundant control platform with transparent bumpless process switchover and easy configuration, PACSystems High Availability facilitates continuous uptime in essential applications.
GE Fanuc‚’s PACSystems RX3i High Availability is designed to keep essential systems running efficiently and reliably by connecting two independent controllers on our proven RMX reflective memory technology link providing up to 2 Mbytes of data synchronization. If an event occurs with the primary controller, the control functionality is automatically switched over to the redundant controller for continuous operations. It serves the needs of applications where continuous uptime is essential to profitability, where bottlenecks must be avoided, remote locations where time and cost to repair is extended, and operations where work stoppage means lost production. It can be found in areas as diverse as protecting critical information in data warehouses, ensuring water quality at water treatment plants, and keeping the power on for hospitals and surgery centers.
PACSystems RX3i offers true dual redundancy data synchronization with dual modules and dedicated, redundant links to one another. They operate with virtually no overhead added to the control application. GE Fanuc‚’s unique, patented Redundant Memory Xchange (RMX) modules, based on reflective memory technology, synchronize the system at the beginning of the input scan and the end of output scan each logic scan execution to keep the controllers in lock step. Furthermore, the systems can be located up to 300 meters apart to so that any localized event affecting one system does not affect the other.
PACSystems High Availability is designed to operate as a single, complete system, therefore eliminating the complex preparations typically associated with synchronizing and data transfer. Configuration is made easy with a Redundancy Wizard that guides the user in setting up shared data and I/O for both systems in a matter of minutes.
GE Fanuc
www.gefanuc.com/highavailability
Filed Under: Factory automation, Motion control • motor controls, PLCs + PACs
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
    • Subscribe!
