Moorpark, CA ‚– Kavlico has recently introduced the P6060 high accuracy pressure sensors that are suitable for air pressure measurements in:
‚• Oxygen concentrators
‚• Respirators
‚• Ventilators
These rugged, lightweight (1.3 grams Max.) devices have a piezo-reseitive (PRT) sense element in a low-profile surface mount package. Small in size, the sensors measure 21.29 x 16.71 mm.
Using a 5 volt input, the sensors provide a 0.5 to 4.5 Vdc linear analog amplified output proportional to pressure. The user has the option to specify a digital output that conforms to SPI protocol.
Internal temperature compensation using a state-of-the-art ASIC insures an accurate ‚±1% of span total error band (TEB) over 0 to +60‚°C. Available pressure ranges include 13‚†H20 and 0-1 through 0-75 PSIA, PSIG, and PSID.
The easy-to-use P6060 sensors are EMI/RFI and ESD protected, experience no mounting position effects and provide a fast response. The sensors can be configured with custom pressure ranges and port connections dependent upon the end-users application-specific requirements.
For applications that do not require a ‚±1% accuracy, the P6050 pressure sensors is available with a ‚±2% TEB specification over temperature. As an additional benefit, the sensors are RoHS compliant.
Filed Under: Sensors (pressure), Medical-device manufacture, TEST & MEASUREMENT
