The trend in industry to process more material, faster and more efficiently calls for a high torque, high misalignment, low inertia servo coupling, with minimal compromise to torsional stiffness. Stainless steel bellows couplings have the highest torsional stiffness of commercially available flexible couplings, making them the best choice for aggressive servo driven applications. But in cases where the two shafts to be connected are mounted to different bearing surfaces, it can be difficult to maintain the precise alignment tolerances normally required.
Utilizing a special, high stiffness bellows and new, high strength connection method, the BKZ handles an average of 2.6x the traditional torque rating at a given outside diameter, and an average of 2.9x more lateral misalignment, opening up the benefits of precision bellows couplings to a whole new segment of machine design and servo motion control.
Accepting bore diameters ranging from 15 to 60mm and torque ratings from 20 to 1000Nm, the BKZ range is available in 4 sizes, with a variety of materials, finishes and the optional self-opening clamp system. View online at http://www.rw-america.com/bellows_couplings/bellow-coupling-bkz-t.php
R+W America
www.rw-america.com
Filed Under: Couplings, Motion control • motor controls
