High voltage Reed switch is presented as world’s smallest
By atesmeh | April 29, 2014
Standex-Meder Electronics (Cincinnati, OH) announced the release of the world’s smallest high-voltage switch: the KSK-1A35/1 miniature reed switch. At a maximum glass length of 10.5 mm and an overall lead length of 34.5 mm, the KSK-1A35/1 can work with applications that may require the extra sensitivity of an ultra-miniature reed switch, while also providing an operating sensitivity range of 20 to 35 Ampere-turns (AT). With electrical characteristics such as a switching voltage of up to 1000 volts of direct or alternating current, the KSK-1A35/1 is appropriate for line or high-voltage applications. It’s hermetically sealed and can operate in temperatures ranging between -40C to 125C, making it suitable for use in almost any environment. The KSK-1A35/1 has flat surface mount leads, enabling paddle orientation and superior surface mount behaviors. Its ruthenium contacts, which contribute to longer life of the switch, are available in form 1A (SPST) (normally open contact), center gap and typical operating and release times are .5 milliseconds and .2 milliseconds, respectively. The KSK-1A35 /1 reed switch operates for millions of reliable switching cycles over its vast lifetime. Applications include:
  • Within sensors; examples of which include proximity sensors, presence sensors, rotation sensors, speed sensors, liquid level sensors.
  • Movement detection, end limit detection, and counting.
  • Many other functions when used within reed sensors or reed relays.
For more information, visit www.standexmeder.com
