Usually, you don’t consider using stereolighography for large objects, as most stereolighography 3D printers have a maximum build size of less than 18 in. cubed. So to used a stereolighography 3D printer to recreate a mammoth is quite a project.
Since 1869, the Mammoth of Lier has been on display at the Royal Belgian Institute of Natural Sciences in Brussels. Almost 150 years later, it is returning to its roots in Lier – albeit in a more modern form. The entire skeleton will be 3D printed by Materialise, in collaboration with the museum in Brussels, and mounted on a quasi-invisible internal structure.
Materialise NV used stereolithography to create the life-size, 3D-printed reconstruction of the mammoth skeleton in one of the largest 3D printing projects achieved. The 320 bones making up the skeleton were scanned and digitally reconstructed and will be printed, finished and fitted with a custom frame to hold up the skeleton. From October onwards, the 3D-printed mammoth will be on display in the Belgian city of Lier, the place where the original mammoth was found.
Reconstructing the mammoth presented a significant challenge for the Materialise engineers. Every one of the mammoth’s 320 bones was scanned at the museum in Brussels, and then the skeleton was digitally reconstructed in collaboration with the museum’s resident paleontologist to achieve the highest degree of anatomical accuracy. Each scan also needed to be cleaned up and prepared for the 3D printer with Materialise Magics software, since a scan simply produces a 3D image instead of a structurally sound 3D form that is suitable for 3D printing.
Instead of using the original 19th century exterior mounting system, a more sophisticated interior mount structure made of carbon will be created and integrated inside the plastic bones – meaning that in the digital phase, Materialise engineers already had to think about how to fit the structure within the bones, integrating entry and exit holes in the bones for the carbon tubes. For the modular carbon structure Materialise drew on the experience of its daughter company RapidFit in the automotive tooling. The result is a sturdy and lightweight structure weighing a mere 300 kg in total.
The bones will be printed on nine of the aptly named Mammoth Stereolithography printers at Materialise, which were specially designed by the company to realize projects that require extra-large printer capacity (with a printer bed dimension of 220 x 70 x 80). The overall build area is more than 2 m.
Materialise will be using its full backbone of 3D printing services, starting from optimizing the scans for the printers, engineering the mount structure inside the bones and printing the mammoth on the most suitable 3D printing technology from the company’s extensive printing facility. Applying 1/10th of a millimeter of resin at a time, the mammoth will take more than one month to print, before being finished and painted with a combination of different paints, textures and lacquers so the bones can match the original skeleton as precisely as possible.
Gertjan Brienen, Project Manager at Materialise, says “The scale of the project is challenging, particularly because we had to bring different experts together, including engineers, paleontologists and finishing specialists, and align our vision of the finished model, all while meeting tight deadlines. The original skeleton presents some inaccuracies, which reflect the knowledge at the time of the original mounting 150 years ago. One example is the length of its tail, which we now know is shorter than initially thought. The original mammoth skeleton is also missing a few bones, including its left tusk. We mirrored the right tusk and recreated it in Materialise 3-matic to achieve a more precise replica than the wooden tusk that was used to complete the original skeleton. The broken upper jaw was also restored accurately by mirroring a part of the original bone structure. This means the 3D-printed mammoth will be more scientifically accurate than the original.”
Said Royal Belgian Institute of Natural Sciences, Dr. Mietje Germonpré, “3D Printing is increasingly proving to be an extremely useful tool in the field of paleontology, allowing us to study fossils without damaging the precious originals, and collaborate virtually on the same fossil with colleagues around the world. Working on the first entire mammoth skeleton ever to be 3D printed has been a unique experience.” says Dr. Mietje Germonpré.
Materialise
www.materialise.com
