Smart RFID reader maintains IP65/67 ratings while securing industrial equipment
By Lee Teschler | November 17, 2020
The new KW2D series of smart radio frequency identification (RFID) readers are
designed for easy installation into the typical 22-mm panel-mount holes used with machinery, are readily integrated with automation systems, and enable OEMs and end users to easily apply advanced authentication and authorization measures.
The IDEC KW2D series RFID readers are compact UL listed and maintain IP65/67 IDEC-KW2D RFID water-, dust-, and oil-proof ratings and feature push-in power supply terminals. A built-in Ethernet port facilitates easy connectivity to host devices like PLCs and HMIs using Modbus TCP. Three-color white/green/red LED lighting is clearly visible from the front and sides—even at a distance—to indicate standby, successful verification, or error respectively, while a built-in auxiliary buzzer provides audible feedback of successful and error conditions.
Users can mix-and-match various RFID tag formats: commercial-style cards, wristbands, stickers, and IDEC-supplied color-coded key fob or card-style tags. The key fob tags are available in five colors, are durable for field conditions, and include enhanced encryption compared with other tag types.
RFID tags are low cost and passive, responding to a short-range radio signal generated by the RFID reader when the two are in close proximity. The KW2D operates at standard 13.56 MHz high-frequency (HF) providing a reading distance of up to 15mm depending on the tag style. Several ISO/IEC communication speeds (type V, A, or F) are supported. IDEC provides the Windows-based RFID configuration software tool free of charge, so users can set up the reader IP address, Modbus TCP server details, tag information, and passwords. Users can take advantage of default authorization levels, or they can customize up to 500 tags with up to 255 authority levels. Configurations can be quickly modified, and lost tags can simply be blocked.
RFID systems are useful for machine tools, material handling, and manufacturing machinery for industries like automotive production, food and beverage, life sciences, plastics, and others. Designers can use the IDEC KW2D RFID reader and tags to supersede traditional locking methods, providing advanced user level access and safety-related authorization. Traceability is established with RFID-sourced timestamped logs detailing operator activities and operations. RFID tags help end users improve productivity in a convenient and cost-effective manner, maximizing safe and secure operation of equipment.
IDEC Corp., 1175 Elko Drive, Sunnyvale, CA 94089-2209, 800-262-IDEC (4332), https://us.idec.com/RFID
You may also like:
  • RFID security
    Basics of security in RFID readers
  • Tips for designing embedded RFID readers
  • Putting food and beverage processors in touch with their operation
  • Implementing IoT one step at a time
  • How can you harvest RF energy?
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels, Sensors (position + other)
Tagged With: idec
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
New igus E4.1R rol e-chain reduces noise, vibration and saves electricity
