Inductive Miniature Linear Displacement Sensor
By Design World Staff | April 13, 2011
Designed for very short measuring ranges between 50 and 200 mm, TURCK developed the first miniature linear displacement sensor, LI-Q17, uniting all the positive qualities of customary measuring systems in one solution without having the disadvantages. The LI-Q17 doesn’t work with a magnetic locator but with the resonant circuit measuring principle, where an object’s position is detected via an inductive oscillating system, consisting of a condenser and a coil. As the only sensor of its kind, the LI-Q17 is able to work reliably where the functionality of a magnetic position device is massively affected by electromagnetic fields–caused by large motors or welding plants.
The robust LI-Q17 in an IP67-rated housing is available in four different sizes with the measuring ranges 50, 100, 150 and 200 mm for a temperature range from -40 to +70 °C. The first models have an analogue output (0…10 V, 4…20 mA, 0,5…4,5 V), and a high-resolution SSI model is going to follow. Despite their compact design, TURCK’s new sensor family has extremely short blind zones of 10 mm at the connecting end and 22 mm at the head end. For the connection, a pigtail with a 30 cm cable and an M12-connecter is required, or an open connection line of 2 m is needed. Because of the thought-out assembly concept, the user can install and operate the LI-Q17 sensor and the provided standard accessories fast and easy. Robust metal clips can be latched into the housing of the sensor and allow either a vertical or a horizontal installation. The electronic module of the position generator is pivoted and allows an exact positioning corresponding to the installation situation. If an application needs a special measuring range, the user can program this on site.
TURCK
www.turck.com.au
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
