Inspector Vision Sensor from SICK
By Design World Staff | May 28, 2008
Minneapolis, Minn. ‚– SICK announces the launch of its Inspector Vision Sensor. The Inspector is an intelligent vision solution in an easy-to-use sensor package. No matter what angle or orientation the product comes down the line, the Inspector is able to verify completeness and quality, even if products vary in size by as much as 20%, something no other vision sensor can do.
The Inspector provides a simple pass/fail output, ensuring only the correct product makes it through. Plus, the Inspector is fast, able to keep up to the quickest line speeds. Applications include verifying label position, date code presence and cap inspection in packaging, as well as bowl feeder inspection and verification of part assembly.
The Inspector offers a 384 x 384 resolution and an IP 67 metal housing, ideal for the toughest environments. The Inspector comes with a unique integrated dome light that delivers high quality images even on glossy and reflective surfaces ‚– without a complex setup.
www.sickusa.com
Filed Under: SENSORS, ELECTRONICS • ELECTRICAL, Vision • machine vision • cameras + lenses • frame grabbers • optical filters • scanners
