  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
InterTest’s 7mm QN Camera lives on in high definition
By Mike Santora | August 26, 2020
QN-HD Size Comparison w Old ModelInterTest, Inc. has redesigned the tried and true iShot 7mm diameter Color Micro Camera QN. They have now introduced the new iShot QN-HD as a high definition replacement and upgrade to the 7mm QN that has been prominent in the remote visual inspection industry for years.
Few camera technologies have had as long a life as the original 7mm Color Micro Camera QN. It was first manufactured by ELMO and Toshiba starting in 1999, and then continued to be made by InterTest until its end of life in 2018.
“The 7mm QN micro camera was an affordable, proven camera solution that was less expensive and with a better picture than other comparable products at the time,” reflected Bill Habermann, founder, and president of InterTest, Inc. “It was quickly adopted by the industry as a standalone and an OEM product. It was the vision sensor enabling many of our remote vision systems.”
Proprietary products like the WebViewer, Polecam 1000, Weld-i 625 all used the 7mm QN camera, and are now offered with the new QN HD model.
The original 7mm ELMO QN42H, and its Toshiba IK-SM43H equivalent, boasted a 410,000- pixel picture with 470 horizontal TV lines, from a 1⁄4-in. CCD sensor within a 7mm diameter package — less than half the diameter of a dime. That was a big deal at the time when most cameras were 360 horizontal TV lines and much larger.
Now the iShot QN-HD carries on the original 7 mm camera’s legacy. The QN-HD still has the same form factor, physical resilience, and functional versatility as the original QN, but now with more than 4 times the resolution in HD. The QN-HD is compatible with existing ELMO QN lenses and boasts a 1080/30p high definition picture utilizing a 1/6” 1920 x 1080 (2 MP) sensor in the same 7mm diameter form factor.
Features:
• USB-C power supply, DVI & USB output for varied application requirements
• 5 standard cable lengths (2m, 3.5m, 5m, 10m, 15m) as well as flexibility in cable length
(up to 15m) with custom fabrication
• 2 cable materials available (Teflon & PVC)
• Lens options include 1.8 mm, 2.5 mm, 4 mm, 7.1 mm, 15 mm and wide-field 2.5 mm right angle
• Compatible with legacy QN lenses
• Instant image capture button on CCU records to micro SD card
• 4 customizable presets for easy and rapid recall of control settings
• Remote control via RS 232 port
• USB camera operations
InterTest, Inc.
intertest.com
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
