J107E1 Series Relay from CIT Relay & Switch
By Patrick Curran | September 29, 2010
Minneapolis, MN – The CIT Relay & Switch J107E1 series is the industry standard 10amp featuring 12 and 24 volt coil. The rugged J107E1 is low in cost and offers a lead time of six to eight weeks. Small in size and robust, this high performance relay is cUL listed and RoHS compliant.
Specifications: Contact arrangement is (1A) SPST or (1C) SPDT with contact rating of 10A@250VAC & 30VDC. Contact resistance is less than 50 milliohms; contact material is AgSnO2. Tested electrical life of the J107E1 Series is 100k cycles with mechanical life of 10M cycles. The dielectric strength is 1500Vrms minimum coil to contact and 750Vrms minimum contact to contact. Insulation resistance is 100MW minimum at 500VDC. Shock resistance is 100m/s2 for 11 ms and vibration resistance is 1.55mm double amplitude 10~55Hz. Solderability at 260°C for 5s. Operating is -40°C to 85°C with storage temperature of -40°C to 155°C. Solderability is 260°C for 5s. Weight is 10g.
The J107E1 Series relay are suitable for HVAC, RV control, security, appliance and emergency lighting, as well as many other switching applications.
CIT Relay & Switch
www.citrelay.com/Relay%20Products.htm
Filed Under: Relays, Switches, ELECTRONICS • ELECTRICAL
