Kavlico P356 Pressure Sensor
By Design World Staff | February 2, 2009
Moorpark, CA — Kavlico has designed the P356 low pressure gage/differential pressure sensor for applications requiring long-term stability and an operational life in excess of ten years.
Typical applications include:
• Pneumatic controls
• Filter monitoring
• Tank level
• Leak detection
Available in pressure ranges of 0-0.5, 0-1, ±1, 0-3, and 0-5 PSI, the P356 provides a linear amplified voltage output proportional to pressure of 0.5 through 4.5 Vdc from a 5 Vdc regulated power supply. Featuring a brass housing and excellent EMI protection, this device has a response time of <10m sec and an operating temperature range of -20° to +125°C. Built-in reverse polarity and over-voltage protection allow for ease of installation while excellent hysteresis, repeatability, and linearity provide accurate measurement.
The P356 is packaged for high volume applications requiring a rugged, compact design while offering flexible configuration options for application-specific requirements. Key to the sensor’s high performance and low cost is Kavlico’s ceramic, variable capacitive sensing element and integral ASIC with hybrid circuit for reliable signal conditioning.
www.kavlico.com
Filed Under: Sensors (pressure), TEST & MEASUREMENT
