Santa Clara, CA – Lin Engineering, the Step Motor Specialists, are pleased to introduce their new line of NEMA 17 dampers. These dampers are durable, long lasting, and can easily be mounted onto standard NEMA 17 step motors.
As motors step, inertia makes the rotor oscillate about its new position. This natural back and forth movement might sometimes contribute to the erratic movement of motors. Adding a Lin damper to the step motor’s shaft translates into smaller oscillations and thus, smoother motion. This reduced step response time can ultimately result in much improved motor performance.
DAMPER SPECIFICATIONS
Wet/ Dry Operation
Inertia
oz-in (gm-cm)
Mounting
Shaft Size
Dry
0.064 oz-in(11.71 gm-cm2)
Set Screw
5 mm
For more information on Lin Engineering's NEMA 17 dampers, please contact us at 408-919-0200 or email us at [email protected]
:: Design World ::
Filed Under: Factory automation, Motion control • motor controls, Motors • servo
