    • On the Floor
Linear Inductive Position Sensors for Clamping
By Design World Staff | November 8, 2011
The BIP linear inductive position sensor is for position monitoring in applications such as drive spindles and clamping devices for tools and workpieces.  The sensor can also be used for many other linear motion applications such as punch depth, grab positions, rolling positions, and valve positions. It is non-contact with linear travel of up to 40 mm. Resolution is 14 microns, repeat accuracy is +/- 80 microns, and non linearity is +/- 250 microns. Available outputs include 0…10 V and 4…20 mA.  The sensor functions in temperatures to 85 °C. Mechanical adjustments are not necessary as the sensor is teachable on site, allowing the measuring range to be adapted to the application. With the IO-Link Variant this is also possible via the control system.
Balluff Inc.
www.balluff.com/BIP
Filed Under: Sensors (proximity), LINEAR MOTION, SENSORS, TEST & MEASUREMENT
  • Industrial automation accelerates with increased capital spending
    • On the Floor
