Misumi Announces New Website Enhancements
By Design World Staff | December 15, 2008
Schaumburg, IL– Misumi USA, Inc., a subsidiary of Misumi Corporation, a part of Misumi Group, Inc. (TYO:9962), announces the development of several website enhancements that are now available. These new Misumi enhancements are outlined below.
New Part Number Checker
One of the benefits of ordering from Misumi is that you do not need drawings and that stock and well as configured components can be ordered by a part number. How to manually configure a component to generate a part number is defined in the catalog, but as the configured part becomes highly customized, part numbers can sometimes become long and complex. Misumi has been providing ways to help automatically generate the correct part numbers through the CAD configurator which allows you to spec the product using menus and is ideal if you are just starting the design process.
The New Part Number Checker is an alternative for those who create the part number manually, but want to do a quick check afterwards to make sure none of the parameters are missing. Until now, customers were required to login and configure or request a quote through our Web Ordering System in order to verify the part number. The Part Number Checker is a simple way to verify the validity of a part number without having to log into the configurator. Up to five part numbers can be verified at once. The system supports all metric part numbers including part numbers from the press and mold catalogs, in addition to the automation components catalog.
Part Number Checker screen.
Screen showing all part numbers were verified.
Screen noting part numbers that are in error.
2009 Online Catalog
The entire 2009 Catalog (2900 pages in printed paper form) is now available online.
Examples of newly added products include:
1. Linear Shaft with Radial Hole
2. Miniature Linear Guide with dowel holes on Rail and Block
3. Medium/Heavy Load Dust Proof Linear Guides
4. Left Hand Precision Ball Screw
5. Square Support Units for Ball Screws
6. LX Actuator, KUA Actuator
7. Shock Absorbing Bumpers
8. TM Magnets
9. Drive Shafts
10. Angular Bearing with Housings
The new catalog is available immediately at https://fa.misumiusa.com. CAD files for the new products will be added monthly, as they become available.
www.misumiusa.com
Filed Under: Ball screws • lead screws, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
