Danielson, CT — SPIROL is pleased to announce the introduction of the Series CL500 and CL550 roll formed, insert moldable Compression Limiters are designed to replace expensive machined limiters.
Compression Limiters are used to preserve a threaded joint’s integrity when fastening plastic-to-plastic assemblies, or plastic-to-metal assemblies. As a bolt is tightened to achieve the required friction between threads, the plastic is compressed. Without the Compression Limiter, plastic will creep, resulting in the loosening and eventual failure of the joint. The Compression Limiter absorbs the load generated when the bolt has been tightened to its recommended value. The plastic is isolated from excessive compressive loads and plastic creep is not a factor in ensuring that the joint remains intact throughout the life of the product.
The standard material for this new series is low carbon steel with a trivalent (hexavalent free) zinc plate finish for corrosion protection. The Series CL500 is designed around standard industry accepted clearances for 6MM and 8MM bolts. The Series CL550 is designed with additional clearance around the bolts to accommodate greater positional tolerances.
This is a new addition to existing SPIROL® Compression Limiter lines consisting of the Series CL200 and CL250 (split seam) and Series CL101 and CL111 (solid knurled) designs.
SPIROL engineers will review your application needs and work with your design team to recommend the best solution at the lowest installed cost. To access this service, select Compression Limiters under the Optimal Application Engineering portal on the left side of this page.
