Moog adds Compact EAS to its Electrohydrostatic Actuation Systems family
By Heather Hall | April 30, 2021
Moog Industrial Group is adding the Compact EAS to its Electrohydrostatic Actuation System (EAS) product family for industrial machinery. EAS is intended for applications requiring high dynamics and power density, use programmable cycles and demand high levels of accuracy and repeatability. Testing machines for automobile components are one target application. In metalworking, examples include metal pressing, cutting, forming and bending. Operations involving pressing, punching and cutting other materials, including glass, ceramics, plastics and leather, will also benefit from its high level of performance.
Compact EAS –linear. (Photo Moog, MGPR2101)
Compact EAS units comprise six elements: a servo motor, internal gear pump, compensation tank, valve block, stop valve and cylinder. Unlike conventional hydraulic systems, everything on the Compact EAS is integrated; there are no pipes or hoses. Pump output and direction of rotation are controlled by the servo motor, eliminating the need for directional or proportional valves, resulting in a defined linear movement of the cylinder. Forces, speed and position on this linear actuation axis are all freely programmable.
The high force capability and force density of all Moog EAS actuation systems provides an attractive alternative to electrohydraulic (EH) or electromechanical (EM) systems. They are quieter, use much less oil and less energy, and have fewer components to maintain.
“The Compact EAS provides users with numerous benefits,” says Harald Branz, sales manager Central and Eastern Europe. “The system is highly dynamic, energy-efficient and requires minimal maintenance. The Compact EAS is easy to configure and integrate into machine systems, providing significant cost advantages over alternative types of actuation systems.”
There are three versions of the new Compact EAS in its standard format:
•linear – the cylinder is on the same axis as the motor;
•parallel – the cylinder is underneath the valve block and moves in the opposite direction;
•orthogonal – the cylinder is mounted vertically underneath the valve block.
There is also a “split” design, in which the cylinder forms its own unit separate from the motor and pump group, without losing any of the advantages of the basic concept.
In its standard configuration, the Compact EAS can produce a movement in the cylinder of up to 640 mm/s with a force of up to 500 kN. Customized versions offer considerably more speed and force. Customers can choose stroke lengths ranging from 50 to 400 mm. Position accuracy is accurate to within 0.01 mm, while position repeatability is down to 0.01 mm.
www.mooginfo.com
Filed Under: Actuators
Tagged With: Moog, mooganimatics, moog animatics
