Multi-axis Motion Controllers from ACS
By Design World Staff | August 5, 2008
PLYMOUTH, MN ‚— ACS Motion Control‚’s advanced SPiiPlus
and MC4U multi-axis motion controllers feature a powerful Sin-Cos encoder multiplier that enables accurate, high-resolution positioning while reducing jitter and settling times.
The SPiiPlus Sin-Cos encoder multiplier features 1Vptp differential inputs that
use a maximum theoretical Sin-Cos encoder multiplication factor of 65,536 to achieve the required high resolution of today‚’s demanding motion applications. With input frequencies rated up to 2.5MHz, the achievable maximum velocity is not dependant on the selected multiplication factor enabling the use of ultra high-resolution laser feedback devices.
The SPiiPlus PCI and linear drives were tested on a high performance XY table
used for wafer inspection with Sin-Cos encoder resolutions of 4nm (250 lines per mm).
Using a multiplication factor of 8,192, ACS engineers measured a jitter of ‚±2 encoder counts, which is equivalent to ~1nm. At this high resolution, the axis achieved velocities up to one meter per second.
www.acsmotioncontrol.com
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
