New Safety Mat System from Omron STI
By Design World Staff | February 25, 2008
FREMONT, CA — Omron Scientific Technologies, Inc. introduces UMQ Series Safety Mats. These safety mats feature a patented IP67 quick-disconnect cable connector that promises significant cost savings to the user by reducing inventory requirements, while simplifying installation and replacement of damaged cables.
The quick-disconnect feature allows for last minute cable length changes in the field, and since the cable is not attached until the end of the installation process, the potential for cable damage during installation is significantly reduced. And even if a cable is damaged during installation or mat operation, it can simply be replaced in the field without having to replace an entire mat. The quick-disconnect is designed for backward compatibility with the mat cable location of current Omron STI safety mats.
Black UMQ series safety mats are available in standard sizes with a standardized cable location. Mat cables are currently available in 5 meter and 10 meter lengths. Mats are also available in metric sizes, yellow color for greater visibility, special angular and cut outs for uniquely shaped areas, and customized cable locations. All Omron STI safety mats are engineered to satisfy ANSI/RIA R15.06-1999, ISO 13856-1:2001, ANSI B11.19-2003, CSA Z432-04 and EN1760-1:1998 standards.
www.sti.com
Filed Under: INDUSTRIAL SAFETY SYSTEMS
