Northwire, Inc., (NWI), a custom cable and assembly manufacturer and subsidiary of The LEMO Group, expands the family of ruggedized hybrid electric vehicle charging cables featuring power, signal, and data custom composite options in any AWG size to suit all electric vehicle applications in today’s market.
While NWI’s Next Gen EV cable suite is compatible with commercial and residential charging applications, their Second Gen EV charging cable will include the same benefits and expand the geographic scope with the UL – cUL – cULus listing that indicates compliance with Canadian, USA and Mexican requirements. Northwire’s Second Gen EV cable will also feature a cold temperature impact rating of -40°C with superior flexibility.
NWI can assist with the complex navigation of international standards and agency compliance. Here are a couple of key points to ensure your UL 62 EVE listed cable meets the revised standard:
- Did you miss the June 2015 deadline to submit samples to UL?
- Is your EV cable jacket custom-colored?
- Have you passed the UL 720 hour UV/Sunlight Resistance test standard?
- Does your EV cable feature 10 gauge or larger copper?
If you answered ‘yes’ to more than one of these questions, Northwire’s Agency Compliance Engineers and Technicians will support your recertification requirements to the revised UL – cUL – cULus 62 listing. With limited time available, the new listing will go into effect March 2016.
“Developed by our R&D Department, Northwire’s robust and versatile material is formulated, designed and manufactured for a wide variety of electric vehicle charging applications,” explains Krista Lindquist, Materials and Manufacturing Engineer with a Bachelor’s of Science in Chemical Engineering. “Ideally-suited for harsh environments characterized by extreme crush and cold temperatures, customers can easily access end-applications in North American markets with the harmonized standards,” emphasizes Lindquist.
Based upon the strong demand for NWI EV cables, Northwire’s goal is to ensure that our Second Gen EV charging cables will be one of the first on the market as soon as the UL listing is granted. Featuring a brittle point of -60⁰C and superior cold bend and cold impact to -40⁰C and backed by NWI’s expertise, product quality and services, the advanced flexibility of NWI EV cables safeguards that they are built to last and ideally suited for:
- Home electrical vehicle charging cable
- Public charging stations
- Neighborhood Electric Vehicles (NEV)
- Roadside assistance trucks
- Battery Electric Vehicles (BEV)
- Fleet trucks
- Hybrid vehicles
- Mass transit vehicles
- Low-Speed Vehicles (LSV)
- Motorcycles
- Personal Electric Vehicles (PEV)
- Watercraft
- Plug-in Hybrid Vehicles (PHV)
- Agriculture vehicles
- Plug-in Hybrid Electric Vehicles (PHEV)
- Military vehicles
- Electric vehicle charging station manufacturers
Northwire’s custom EV cables are engineered to withstand high temperatures of 105°C and harsh environments, including resistance to abrasion, crush, oil, chemical, ultra-violet, weld flash and weld slag. Suitable for wet location use and compliant to RoHS2, NWI’s Second Generation EV cable is UL 62 Listed, compatible with SAE J1772 connectors, UL 2594 and NEC 625 charging systems. VW-1 and FT2 rated, Northwire’s 300 and 600 Volt EV cable is non-marking and available in standard straight or retractile options with custom configurations that include composite designs, custom colors and private labels.
Northwire
www.northwire.com
The post Northwire’s UL harmonized electric vehicle cable meets revised compliance requirements appeared first on Wire and Cable Tips.
Filed Under: Wire & Cable Tips, Cables + cable management
