Control knobs cater to menu-driven electronics
By Lee Teschler | May 5, 2022
OKW’s elegant rotary/click control knobs now feature a new, improved design with greater illumination (option). Ergonomic CONTROL-KNOBS are candidates for the central element for menu-driven electronics – typically for devices manufactured in high volumes. Applications include measuring and control; medical, wellness and laboratory technology; HVAC; communications; Smart Factory and building control systems.
These soft-touch tuning knobs fit rotary potentiometers or encoders with round shaft ends (DIN 41591). Illumination is via SMD LED technology (5 V). RGB LEDs allow individual lighting okwand colors, illuminating a translucent optic ring on the top. OKW has increased the number of LEDs on the larger knobs from eight to 12. (The smaller knobs have eight LEDs).
The knobs can be specified with or without a pointer line on the side. They fit securely on potentiometer spindles, using the tried and tested collet fixture system. The maximum torque for installation is 1.5 Nm (function 1.2 Nm).
Each knob comprises two parts – a hard inner body made of robust polycarbonate and a soft-touch TPE outer shell with a smart and practical grooved appearance. They are available in two sizes: ø 36 mm and ø 46 mm (boreholes 6 mm, 1/4 in). The standard colors are nero black and volcano gray. Accessories include LED illumination kits, bases, covers, round nuts and a spanner.
OKW can supply CONTROL-KNOBS fully customized. Services include CNC machining, printing, laser marking and installation/assembly.
OKW Enclosures, Inc., 3000 Old Pond Road, Bridgeville, PA 15017, 412 220 9244, Fax: 412 220 9247, E-mail: [email protected], www.okwenclosures.com/en/Potentiometer-Tuning-knobs/Control-Knobs.htm
You may also like:
  • hiring engineers
    The real reason for hiring engineers
  • PoF
    The physics of failure
  • LTspice
    Best free analog circuit simulators
  • engineers and innovation
    Most engineers aren’t innovators
  • PCB mills
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
Tagged With: okwenclosure
55416_commModule_APL_300dpi_cmyk
Softing introduces a hardware module for implementing Ethernet-APL field devices.
IO-Link Smart Field I/O System from AutomationDirect
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
