    • Subscribe!
Pilot Lights So Bright You Can See Them from Every Angle
By Editor | September 16, 2013
New AP22M pilot lights introduce a unique optical design making them twice as bright as standard pilot lights when viewed from the front and up to 100 times brighter than standard pilot lights when viewed from the side! When your application demands accurate recognition and high-intensity, nothing shines like AP22M indicators.
AP22M pilot lights are ideal for outdoor applications where visibility from any angle and status indication are crucial at any time
AP22M pilot lights are ideal for outdoor applications, such as operator controls for machinery and equipment, control panels, and public information systems, where visibility from any angle and status indication are crucial at any time, even in bright sunlight. These pilot lights also work well in indoor applications where high visibility is required due to bright, indoor lighting or even conditions where dirt and dust buildup is common. With a Type 4X rating, the AP22M can be used in nearly any environment without concern for durability.
These pilot lights are available in red, green, yellow, amber, blue and white with a choice of colored lenses for bold, vibrant colors, or a clear lens for exceptional contrast between on and off. AP22M pilot lights have an integrated terminal cover with IP20 finger-safe screw terminal connections, as well as being UL/c-UL Listed, and EN standard compliant.
IDEC
www.idec.com/usa
Filed Under: Electronics • electrical, Lights • signal lamps • indicators
Tagged With: idec
molex-premo-flex
    • Subscribe!
