Power Machine Tray Cable from AutomationDirect is available in sizes from 18 to 8 AWG with 3 to 25 unshielded conductors. Individual conductors are bare copper and stranded for flexibility, with black PVC/nylon insulation and marked with numbers for easy identification.
The black thermoplastic elastomer (TPE) cable outer jacket is flexible and resistant to sunlight, oil, and moisture penetration; making the cables suitable for wet and dry indoor and outdoor locations.
With a Tray Cable Exposed Run rating (UL Type TC-ER), the cable can be installed not only in a cable tray but also between the tray and devices or equipment without metal conduit, resulting in installation and maintenance savings. Other ratings and approvals include UL Type MTW (Machine Tool Wire), UL Type WTTC (Wind Turbine Tray Cable), Class 1 Division 2 Hazardous Locations and Direct Burial.
Power Machine Tray Cable from AutomationDirect is available in cut-to-length 1-ft increments starting at $0.41 per ft (with a 20-ft minimum).
AutomationDirect
www.automationdirect.com/tray-cable
