Press-fit contacts for elbow and straight PCB sockets
By Mary Gannon | May 18, 2020
LEMO Harpoon pin press contactsLEMO connector is well known for its Push-Pull connector. Its new harpoon earthing pins enable preinstalling easily various receptacles/socket. The advantage of these new press-fit contacts is the gain of time while doing the pre-assembly, so there is no need to place the washers and screw 4 times the M1.6 screws. Simply align the connector and push firmly.
This pre-assembly will enable the assembly house or final customer to turn the PCB board upside down and run the parts through the reflow soldering oven. This solution is planned for elbow and straight PCB sockets of 0B & 1B series. The current design works specifically with
1.6mm thickness boards.
LEMO SA
www.lemo.com
Filed Under: Connector Tips
Tagged With: lemousa
RF connectors cover DC to 90 GHz
binder USA introduces M12 K- and L-coded connectors for North America
Why connector return loss causes signal problems
Driving standards: The latest liquid-cooling cables and connectors for data centers
