RA Series Rocker Switch
By Design World Staff | January 14, 2009
Minneapolis, Minnesota ‚– The RoHS, UL / CUL recognized RA Series rocker offered by CIT Relay & Switch has eight switch function choices including an LED option with On-Off function. The RA series offers housing color choices of black, white and grey with six actuator color choices making this extremely versatile rocker switch a go-to for electrical designers. Teamed with thirteen actuator marking choices and three LED colors, and terminals options including quick connect, solder lug, PC pins, right angle PC pins and left angle PC pins, the RA Series rocker fits a wide variety of applications.
Specifications: Switch function is single pole single throw or single pole double throw. Electrical ratings are 15A at 125VAC or 8A at 250VAC. Electrical life is 10k cycles with contact resistance of less than 50mW. Dielectric strength is 1500Vrms and insulation resistance is greater than 100MW. Operating temperature and storage temperature are -40‚°C to 85‚°C.
Actuator and housing are 6/6 Nylon with silver alloy contacts and terminals are tin plated brass.
www.citrelay.com
Filed Under: Electronics • electrical, Switches
molex-premo-flex
