The model CRBAMP-100-6000 is a low-noise general purpose connectorized amplifier covering a frequency range of 100MHz to 6GHz. The amplifier is housed in a custom aluminum enclosure (1.25 x 1.25 x 0.59 in.) with three SMA connectors for both input and output as well as the power supply input. The unit operates from a single +5 V supply consuming only 60 mA.
This broadband, low-noise amplifier has a small signal gain of 18 dB with an output power of 17 dBm (P1dB). It features a typical noise figure of 3.5 dB with an IP 3 of +30 dBm.
The CRBAMP-100-6000 is ideal for use in applications such as IF or RF buffer amplifiers, base stations, high-reliability applications, and general lab use for in-house testing.
Crystek Corporation
www.crystek.com
