ROLEC’s technoBOX ABS electronic enclosures are now available in 10 sizes, many of which are compatible with other standard products.
Tough modern technoBOX is a cost effective range of enclosures suitable for a wide range of industrial electronic and electrical applications.
Separate screw channels outside the enclosure’s interior maximise the space available for components. The ergonomic and aesthetically pleasing bevelled lid is recessed to accommodate a membrane keypad or front plate. The lid screws are made of corrosion-resistant stainless steel and are captured to avoid accidental loss. Threaded screw bosses in the lid and base enable the installation of PCBs, mounting plates and terminal rails.
ROLEC’s technoBOX is moulded from light gray (RAL 7035) ABS (UL 94 HB) as standard. It is rated to IP 66 and is GOST approved. Sizes range from 2.59” x 2.00” x 1.37” to 9.48” x 6.33” x 3.15”. Prices start at $15.
Options include external mounting brackets which can be turned by 90°.
Customization services for technoPLUS include CNC machining, custom colors, anodizing, printing, engraving/laser engraving, RFI/EMI shielding, membrane keypads and full assembly.
ROLEC Enclosures, Inc.
www.rolec-usa.com
Filed Under: Design World articles, TIPS SITES (EE World), Electronics • electrical, Flanges • supports • mounts • brackets
