    • On the Floor
Selco Introduces LED Assemblies and Single Package LED Components
By Design World Staff | June 4, 2009
RENO, NV ‚– Selco Products Company has expanded its product offering to include the new CL Series LED Lighting Assemblies and Single Package LED Components. Both product lines feature high-bright lighting and low power consumption suitable for a variety of applications.
The CL Series Assemblies are self-contained electronically controlled lighting fixtures that emit a constant light output of 240 to 400 Lumens (depending on model) with wide input voltages ranging between 9-29 VDC. Power consumption is only 4.3 Watts for the 240 Lumens output model and 7.1 Watts for the 400 Lumen output model. The new LED Assemblies are aimed at aftermarket users as well as manufacturers of freight trucks/trains, trailers, boats, campers/RVs, mass transit systems, and emergency vehicles. The assemblies are also suitable for any low voltage applications such as solar, outdoor security, and remote access lighting, or virtually any lighting requirement where long life, ultra-low power and 160 degrees of optical light emission is desired. Further application versatility is provided with an inexpensive AC-DC converter power source (9-29V DC output) that allows use with batteries.
Designed for rugged environments, Selco‚’s CL Series LED Lighting Assemblies feature high vibration, shock resistance, a wide operating temperature range of ?40 to +60 C, and waterproof housing (meets IP69K High temperature salt water pressure cleaning specifications/ SGS Approved). Having a low profile of only 0.5‚”, just two mounting screws, and auto polarity connectivity ? installation is fast and easy. Providing optimum safety, the new lighting assemblies do not emit any IR or UV and contain no glass or toxic substance such as mercury. Modified and customize assemblies with private labelling are also available.
www.selcoproducts.com
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
  • Toyota goes all-in on humanoid robots
  • Mobile robotics moves to the textile industry
    • On the Floor
