Self-Clinching Flush Nuts Install Without Protrusions
By Editor | May 8, 2013
PEMSERT self-clinching flush nuts introduce solutions for attachment applications where thin metal sheets can benefit from the introduction of strong load-bearing threads without creating any protrusions on either side.  Upon their permanent installation in aluminum or steel sheets as thin as .060” / 1.5mm, both the top and bottom of the sheet remain flush with only a single mating screw required for final component attachment.
These Type F self-clinching nuts particularly can be installed flush before bending or forming operations get under way without risking potential interference problems that protruding fasteners could cause down the line.
Installation is accomplished easily by preparing a properly sized round mounting hole in the sheet, placing the shank of the fastener into the hole, and applying sufficient squeezing force to embed the nut’s unique hexagonal head flush in the sheet.  The metal displaced by the head then flows evenly and smoothly around the back-tapered shank of the fastener to securely lock the nut permanently into place.  The hexagonal head and self-clinching design ultimately ensure high axial and torsional strength.
PEM-Flush-Nut
PEMSERT Type F self-clinching flush nuts are manufactured from 300 Series stainless steel in thread sizes #2-56 to ¼-20 / M2 to M6 and can be ordered to conform with US NASM45938/4 aerospace standards.  Detailed specifications, CAD models, and performance data (Bulletin F) for these RoHS-compliant fasteners can be accessed at www.pemnet.com.
PennEngineering
www.pemnet.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts
Tagged With: PennEngineering
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
