Semi-rigid cable assembly for high-frequency microwave and RF designs
By Mary Gannon | February 15, 2019
Intelliconnect, Crossville, Tenn., has expanded its cable assembly offering for high-frequency and mission-critical applications. Comprised of high-quality cables, connectors and terminations, this RF cable assembly product offering now includes low loss, semi-rigid, semi-flex and conformable versions. The microwave and RF cable assembly offering is designed for a wide range of applications including marine, medical, mil/aero, microwave communications, oil and gas, rail traction, test and measurement, and more.
Intelliconnect Semi-Rigid Cable AssembliesThe low loss phase-stable flexible microwave cable assemblies meet some of the highest specifications available in the industry. Available in a variety of sizes and performance specifications, these assemblies operate up to 70 GHz and beyond and can be armored internally or externally. Phase matching is also available and assemblies can be specified as matched sets or built to a specified phase length. Phase matching is essential when connecting to multi-channel receivers, as individual channels are required to match and track each other over the frequency of operation.
The semi-rigid cables are made using a solid metal outer conductor (usually copper or aluminium) that can be bent into shape as required. Performance figures are improved using a solid outer conductor and they are typically available in 0.047, 0.085, 0.141 and 0.250 in. diameters. Semi-rigid cable assemblies offer low loss, low VSWR performance, are phase stable and can be phase matched, allowing customers to specify the electrical length in time or degrees at the frequency of operation for a specific cable assembly.
Semi-flexible cables offer a lighter, more flexible alternative to semi-rigid types and enable cables to be flexed. Although there is a slightly reduced performance compared with semi-rigid, it benefits from being able to use standard semi-rigid cable connectors and is typically available in 0.085 and 0.141 in. diameters.
Conformable or hand-formable cable assemblies are ideal for applications that require cable to be formed at the time of installation without the need for bending tools. Comprising of a tin-soaked copper braid, the cable stays in place after bending, can use standard semi-rigid cable connectors, and there is no major degradation of electrical performance when cables are formed into shape.
“While a few applications still exist for high-volume cable assemblies, the majority are now low volume, custom designs for specialized products or systems and require close cooperation with system design engineers,” said Roy Phillips, Managing Director of Intelliconnect USA. “Such products do not suit offshore manufacturing and working with a US-based cable assembly manufacturer such as Intelliconnect has many advantages for end users.”
Intelliconnect USA
www.intelliconnect.co.uk
Tagged With: intelliconnect
igus advances the circular economy with the first e-chain made entirely of recycled material
igus becomes world’s first manufacturer to receive UL approval for halogen-free TPE cables
igus expands E4.1 e-chain modular system for long travels
zuken
Harness-building software simplifies quoting process, automates harness documentation
