Hi-Flex Shielded Signal Cables from Cicoil, Valencia, Calif., are compact, flame retardant cables free of contaminants and halogens that have been engineered to provide uninterrupted data transmission, space efficiency and consistent electrical characteristics.
Cicoil’s patented computer-controlled extrusion process allows each individually shielded pair to be placed in a flat parallel profile, precisely controlling the spacing of each individual component, insulation thickness and the overall cable shape. This ensures that each of the shielded or unshielded conductors do not rub against each other, wear during operation and provide optimum EMI/RFI suppression.
The tear resistant Flexx-Sil jacket is also self-healing from small punctures and will not wear, crack or deform due to long term exposure to continuous flexing, severe impact, vibration, water, abrasion, ice, steam, sunlight, humidity, ozone, UV light, autoclave, expanded temperatures (–65 °C to 165 °C) and many chemicals.
Standard “off the shelf” Hi-Flex Shielded Signal Cables are available for immediate delivery and cable assemblies, complete with connectors are offered in 3, 6 and 12 ft lengths. Custom designs are also available . In addition, anti-friction coatings, impact resistant Super Tuff jacketing and custom shape designs are available by request.
Cicoil’s Flexx-Sil Jacketed Shielded Signal Cables are UL and CSA Recognized, CE Conforming, RoHS 2 & REACH Compliant, Class 1 Clean Room Rated and are cured continuously, with no debris or material contamination in an automated, climate controlled environment.
Cicoil Corp.
www.cicoil.com
The post Shielded signal cables provide uninterrupted data transmission appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
