Pepperl+Fuchs introduces Transmitter Power Supply Signal Conditioners. Featuring various inputs for standard voltage and current inputs, these 1-channel signal conditioners offer maximum installation flexibility to suit a wide range of application needs. Input and output signal ranges are selected by switches located on the front of the device. This enables fast, easy set-up and setting duplication, without the need for any software and eliminating the need for tedious input/output scaling.
The transmitter power supply signal conditioners deliver reliable, easy-to-implement and cost-effective power isolation in non-intrinsically safe applications that don’t require a display or scaling. They provide the user with a transmitter power supply and signal converter in one device, for maximum application flexibility. KFU8-VCR-1 can be powered by a wide range of AC or DC power, and is ideal for small projects where they offer easy set-up without software. In applications where the outputs are used not only with signal meters but also with additional trip values and control units, the output needs the ability to drive higher loads. The KFU8-VCR-1 has the ability to drive up to 750 ohms.
Pepperl+Fuchs
www.pepperl-fuchs.us
Filed Under: Power supplies, ELECTRONICS • ELECTRICAL
