TAMPA, FL: TRI-TRONICS COMPANY, INC. has introduced the first “True Color Sensor” designed to perform as well as an instrument or a spectrometer. The new SMARTEYE® ColorWise™ Sensor will solve the most difficult color applications at higher speeds than color cameras or other sensors; ideal for intricate color sorting or inspection problems found in today’s high speed packaging and production lines.
A unique 4 Channel Monitor provides users with a continual visual confirmation of performance. With a choice in speed versus resolution, the performance of the sensor is controlled by the operator… providing a wider range of application solutions.
FEATURES AND BENEFITS
*Low cost color solution vs. cameras, other sensors or spectrometers
*Solves difficult shade-to-shade or color-to color applications
*Selectable outputs, timers, resolution, speed, etc. to fit any/all applications
*4-Channel Monitor for at-a-glance performance feedback
*4 Digital Outputs and 3 Analog Outputs
*Selectable Speed versus Resolution
*Selectable Color versus Color + Intensity
*Captures color from HMI, PLC or remote button
www.ttco.com
Filed Under: Packaging, SENSORS, TEST & MEASUREMENT
