Solid Disk Handwheels from JW Winco
By Design World Staff | August 29, 2008
NEW BERLIN, WI — J. W. Winco, Inc. announced it now offers Solid Disk Handwheels, available with or without Revolving Handle.
Made of aluminum and available in metric and inch sizes, these disk handwheels are distinguished by modern design. For most applications, the highly-polished turned rim and matte gray, shot-blasted, satin finish does not require painting or other surface treatments.
The disk handwheels are gravity die-cast. The rim is concentric and square to bore. An optional revolving handle is constructed of matte black nylon plastic with a zinc-plated steel threaded spindle. Revolving handles, countersunk washers for handwheel retention, and disk handwheels in a matte black, powder-coated, pebble finish are offered for separate purchase. Other modifications, such as keyways, set screw holes, and more, are available upon request.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins, Mechanical
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
