Spectronics Corporation has introduced the powerful Spectroline®TRITAN™ 365 (P/N TRI-365H) forensic inspection lamp. This ultra-high intensity, broad-beam, multi-LED UV/white light lamp is perfect for forensic investigation and laboratory work. It enhances the detection, inspection and photography of biological stains, latent fingerprints, untreated blood, bodily fluids, processed blood samples and much more.
The TRITAN 365 features three ultra-high-flux UV LEDs for a wide range of forensic inspection applications, plus a white light LED to illuminate dimly lit areas. The unit is compact and lightweight, weighing just 16 ounces (454 g). A convenient three-way rocker switch allows easy control of the light sources, while its lightweight, angled lamp body ensures fatigue-free inspections. Just a push of a button turns the lamp on instantly at full power!
A rubber bumper with a Borofloat™ glass lens protects the LEDs from damage in high-risk situations. A built-in fan keeps the LEDs cool, providing optimum light output during lengthy use. The lamp provides twice the output of conventional 150 watt lamps and has a 100,000-hour LED service life.
The TRITAN 365 includes UV-absorbing glasses and is packed in a soft carrying case.
Spectronics
www.spectroline.com
Filed Under: Lights • signal lamps • indicators, MORE INDUSTRIES, MOTION CONTROL
