SPH Helical Gearbox
By PD&D Staff | August 2, 2012
GAM Gear (Mt. Prospect, IL) has introduced the SPH series inline planetary gearbox. Featuring helical gearing, the SPH brings a new level of power and precision to an extensive portfolio of gear technology which includes hypoid, spiral bevel, spur, and worm. Features include:
  • Cut at an ideal angle to help reduce axial forces.
  • Wider gear teeth which allows for larger permissible torques relative to the frame size.
  • Heavy duty taper roller bearings to enable large loading capabilities.
  • Availability in six frame sizes from 50 up to 180 mm and with ratios up to 100:1.
For more information visit www.gamweb.com.
Filed Under: Industrial automation, Gears • gearheads • speed reducers
