Stainless Steel Hinges
By Design World Staff | December 19, 2008
NEW BERLIN, WI – J. W. Winco, Inc. announced the availability of GN 237-NI series Stainless Steel Hinges with Countersunk Thru Holes.
Both the hinge body and pin are constructed of stainless steel. A zinc die-cast version with black powder coated textured finish is also available. For certain minimum quantities, an aluminum version of the hinges is offered upon request. Various metric and inch size fasteners and kit packages are available upon request. These hinges are RoHS compliant.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
