Strain Gauge Measurements Via Ethernet
By Design World Staff | August 1, 2007
The 2612 smart I/O modules allow simultaneous measurement of up to four 350 strain gauges per module. Two voltage sense lines for the bridge input provide a true 6-wire measurement with 200 nV resolution at a 6 Hz rate. The 2612’s microcontroller provides I/O services to the remote 2601 client via a category-5 cable. The cat-5 cable supplies isolated serial communication and power to the 2612’s microcontroller.
The module has circuitry that automatically and periodically measures on-board reference standards to update the gain and offset of each channel. Subsequent readings use the newest computed gain, offset and bridge input voltage. Factory calibration constants are stored in non-volatile memory so that modules can be replaced without requiring field calibration. A 14-bit A/D digitizes all analog inputs and internal references at two 150 ms intervals. Each input’s averaged results are stored in on-board memory. The module has four A/D converters and no multiplexing is necessary. Linux and Windows drivers and demo applications are included as is a Labview software interface.
Sensoray
www.sensoray.com
Filed Under: Data acquisition + DAQ modules, Ethernet — cables • hubs • switches
Tagged With: Sensoray
