The FPM-5171G, a 17 in. color TFT LCD flat panel monitor, is specifically designed for industrial applications. It features Direct-VGA and DVI-D signal transmission, which allows a VGA control card to be used within the user‚’s system.
The onscreen display function lets the user adjust the images on the screen to their preferred setting. Main features include resolution up to 1280 x 1024, lockable OSD keys with two user-defined contrast/brightness settings, flat-sealed front panel, front-accessible USB connector, optional combo RS-232 and USB interface for touchscreen function, and 10 to 30 Vdc power input. The FPM-5171G has a robust design with anti-rust chassis, aluminum die case, NEMA4/IP65-compliant front panel, and supports panel, wall, desktop, rack, or VESA arm mounting.
Advantech Corporation, Industrial Automation Group
www.advantech.com/ea
Filed Under: Displays • HMIs • operator interfaces • monitors, Industrial computers, ELECTRONICS • ELECTRICAL
