    • On the Floor
Three phase EMC Filters for UPS up to 150A
By Design World Staff | August 4, 2011
IT systems are increasing every day, electronic devices that support them are more complex but also more reliable and they are able of working with adversities as failures in the power grid, either due to lack of supply or because quality of electric power is not good enough. Faced with these adversities, UPS is the best solution, providing stable power with high quality, although autonomy is limited.
Current UPS store energy in batteries in DC mode. When necessary, supply such power in AC mode, thanks to a DC/AC converter. This converter works in switch-mode and generates electromagnetic noise, both conducted and radiated, which affects to its operation and the nearby electronic devices. This electromagnetic emission has to meet the limits established by the standard applicable, and the environment in which it is supposed to work, as well as to ensure optimal functionality of the UPS. Typical standard are EMC IEC 62040-2 and EN 50091-2.
PFT Series
One of the EMC test to carry out is the conducted emission test. In this test the noise in the power is measured, using a LISN. The measurement frequency is 150 kHz to 30 MHz and the maximum limit allowed depends on the applicable standard and the environment where they are going to work, domestic or industrial.
To overcome these conducted emission tests, Premo Group offers a wide range of EMC filters for UPS, with various ranges of current, voltage and filter stages, designed and built according to UL1283 and EN60939-2 standards.
PREMO offers PFT series, a three-phase with neutral filter, specially designed for three-phase UPS without transformer.
PFT Series offers currents from 3 to 150A and working voltage up to 520Vac, 50/60Hz, providing high common mode attenuation and differential, as well as low leakage current.
This family of filters offers a compact design and is available in different versions, with fast-on connection, screws or terminal blocks.
These filters have been developed to fulfill the specific needs of this application in terms of attenuation levels, volume, weight, connections, etc. Premo continuously improves its EMC filter designs, in collaboration with development centers, universities, suppliers and customers, innovating in new technologies such as IPEM and introducing new magnetic materials (nanomaterials, new alloys, etc.) to achieve optimum results in operation mode, reliability, size and efficiency.
PREMO recommends the use of this EMC filter in new or existing designs.
Premo EMC has fixed and on-site laboratories to carry out the EMC tests in machines or installations of its customers and a solution is given or suggested in order to fulfill a specific EMC standard.
PREMO
www.gruporemo.com
Filed Under: Power supplies, Terminal blocks, ELECTRONICS • ELECTRICAL
    • On the Floor
