Three-phase monitoring relays with wide input voltage range
By PR Editor | October 29, 2019
CARLO GAVAZZI announces the launch of several new Three-Phase Monitoring Relays that feature a wider input voltage range. These models, part of the DPB and DPC families, are suitble for distributors and customers as they reduce the number of individual items that need to be stocked.
The new DPB and DPC models feature an upgraded switch mode power supply, which provides a wider input voltage range to cover different mains voltages, while reducing heat dissipation and improving reliability and stability. The DPB series has an input voltage range of 208 Vac to 480 Vac, while the DPC series has an input voltage range of 208 Vac to 690 Vac. All of the new models feature an expansive frequency range of 50 Hz to 400 Hz, making them ideal for a wide range of applications.
Three phase monitoring relays protect motors from severe damage that can result from loss of a phase, phase imbalance, or phase reversal. Motors can be found in a wide range of applications, including: HVAC systems, water treatment, material handling, machine tool, marine and aviation.
Key features of the DPB and DPC Three Phase Monitoring Relays include
• Noise, harmonics, and transient filtering
• Significant reduction in power consumption versus previous models
• Wide input voltage and frequency range
• Voltage ranges selectable by DIP switches
• DIN Rail mounting
• Plug-in option available for DPB series
CARLO GAVAZZI
www.GavazziOnline.com
Filed Under: Industrial automation, Relays
Tagged With: carlogavazzi
