TURCK introduces new overmolded Mil-Spec Cordsets for rugged applications. Offering a more robust connectivity solution than field-assembled versions, these Mil-Spec Cordsets are 100 percent factory tested to ensure optimal performance for applications in harsh environments, including automotive, mobile equipment and oil and gas.
Featuring a unique overmolded design, TURCK Mil-Spec Cordsets eliminate field assembly, soldering and wiring—allowing operators to reduce downtime and maintenance labor and costs. Overmolded cordsets also provide the flexibly to seal to a wide variety of cable types. For easy application integration, these Mil-Spec Cordsets are compatible with other TURCK products and standard Mil-Spec receptacles.
TURCK overmolded Mil-Spec Cordsets are available in shell sizes 8-24, in addition to threaded, bayonet and reverse bayonet styles. They meet NEMA 1, 3, 4 and 6P and are rated IP67 and IP68. Cable options include NEK 606, ABS and IEEE 1580.
TURCK
www.turck.com.au
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical
